Bionet - BM3 Plus
by Bionet
The BM3 Plus series monitors are especially designed to be used in a human environment. Compact design coupled with a unique handle make it easy to move from room to room. It's 8.4” Widescreen color monitor displays all the vital signs in different colors for easy recognition. A built in printer offers hard copy documentation of all measured values as well as up to 3 waveforms of information. Alarms and settings are easily adjustable and are retained after turning off the power. [list] [b]Includes:[/b] [*] ECG, SpO2, NIBP, Respiration and Temperature [*] Pacemaker detection indicated on the ECG Weaveform display [*] 58mm built-in chart recorder - Graphical and Tabular Trends of printing [*] Visible alarm lamp handle [*] 8.4" color high resolution TFT screen [*] Battery operation [*] SpO2 Pitch Tone [b]Options:[/b] [*] 5 lead ECG cable, Temperature probe (Skin), Temperature Probe (Skin or Esophogeal/Rectal) [/list]
1ReplyWed Sep 21 2016 | How to do self test with printer. How do you make printer do a self test to see if working Reply |
0RepliesSun Sep 29 2013 | BM3 Please help me sending BM3 Plus Service Manual.
Thanks Francisco Reply |
1ReplyFri Aug 02 2013 | MANUAL I'M LOOKING FOR THE USING MANUAL FOR THE BIONET BM3 ECG I Reply |
[list] Superior Advantages [*] ECG, SpO2, NIBP, Respiration and Temperature [*] 8.4" color high resolution TFT screen [*] Individual sweep speed setting for each parameter [*] Multiple display modes [*] Remembers your settings [*] Usable for adult to neonatal patient Enhanced Data Management [*] 128 full hours trend and alarm information are stored [*] Continuous and Spot - Check mode [*] 20*8sec waves are stored Transportable [*] Li-ion rechargeable battery allows cordless use for up to 2 hours [*] Less than 3kg (7 lbs) including battery [/list]
| Height | 250 mm |
| Length | 163 mm |
| Weight | 3.1 kg |
| Width | 238 mm |
Display, Resolution:8.4" color TFT, 800 x 600 pixels Indicators: - Up to 3 waves (ECG, SpO2, Respiration) - Categorized alarms (3 priority levels) - Visual alarm lamp - Heart rate, SpO2 tone - Battery status - External power LED Interfaces: - DC input connector: 18 VDC, 2.5A - Defib Sync Output - Signal Level: 0 to 5 V pulse - Pulse Width: 100 +/- 10ms - LAN digital output for transferring data - VGA output Battery: - Battery Type: Li-ion - Battery status indicator Operating Time: 2 hours typically (fully charged)
