Syneron-Candela - CO2RE
by Syneron-Candela
Versatile Fractional CO2 Resurfacing System
CO2RE is a versatile fractional CO2 system that enables precise targeting and effective treatment of the skin's surface, middle and deep dermal levels. Perform fractional CO2 resurfacing, traditional ablation and minor dermal excisions with the unique ability to treat both superficial and deep skin layers simultaneously with precision-control over the intensity, pattern and depth of ablation.                  It is optimal for Fitzpatrick skin types I-III, and is the obvious choice for skin rejuvenation and wrinkle reduction when practitioners and patients understand the treatment tradeoffs of superior, single-treatment results for elevated discomfort and downtime. Flexible and targeted, CO2RE technology makes this decision easier by delivering predictable and often dramatic results quickly and with less discomfort than some other systems.                  When a fractional ablative treatment is the best option and superior results are critical to the patient in a single treatment session; CO2RE is the obvious choice for skin rejuvenation and wrinkle reduction.
FORUMSView All (6)
-VaBo
Tue Jun 04 2024
Manual
Scanner using modes
Equipment: Syneron-Candela - CO2RE
-ICDerm
Thu Apr 04 2024
Touch screen non-responsive
After using the laser for about 10 minutes, the screen slowly stops responding to touch commands. Is this due to the touch screen itself failing, or is there a board that needs to be replaced? Anyone know the generic service codes for the CO2re? It has the old software. harrisbw@hotmail.com
-Laser J
Tue Aug 09 2022
Aiming beam
Trying to repair my co2re. The aiming beam is not centered properly. I've got the thing opened up. Any advice on aligning the aiming beam properly? I'm having a tough time... Josh@thelaseragent.com
[list]         System Features:         [*] Intuitive touch-screen interface –displays treatment geometries & selections  [*] Programmed to learn as you work  [*] Monitors its own performance  [*] Stores and automatically recalls preferences    Featherweight Articulated Arm:  [*] Continuous beam centering for reproducible treatment patterns  [*] Minimizes operator fatigue    Digital SuperPulsed Laser:  [*] Delivers the complete matrix of ablative pulses with exceptional speed and precision  [*] Rapidly varies the laser energy for multilevel treatment capabilities  [*] High performance design for extreme reliability and long service life    High Precision Inboard Scanner:  [*] Digitally synchronized with the Laser Pulse Generator  [*] Changes the position and depth of injury hundreds of times per second  [*] Allows different parts of the same scan matrix to be placed at different depths  [/list]
Laser TypeC02
Height177 cm
Length 44 cm
Weight58 lbs
Wavelength10600 nm
Width40 cm
Output Power: 60 watts (maximum peak)      Mode Quality: (M²) 100:1 linear (orthogonal to mounting pads)         Maximum Scan Area: 10 mm diameter         Aiming Laser: 5mW, 650nm (red) diode laser      User Interface: 10.4" high-resolution color LCD Touch-screen technology         Laser Emission Control: Footswitch
NEWSView All
Syneron Announces US and Canada Launch of CO2RE System Following...
New fractional CO2 resurfacing laser offers practitioners broader and highly effective treatment options YOKNEAM, Israel and IRVINE, Calif., Nov. 30, 2010 /PRNewswire/ -- Syneron Medical Ltd. (Nasdaq: ELOS), www.syneron.com, the global leader in the medical aesthetic device marketplace, announced today the US Food and Drug Administration (FDA) a...
