Cynosure - Apogee Elite
by Cynosure
Two-in-One Laser System
The Apogee Elite contains two laser systems - a 755nm Alexandrite laser and a high powered 1064 nm Nd:YAG laser - in one convenient unit. The Elite offers the most optimal wavelengths for hair removal, pigmented lesions, facial and leg telangiectasias and treatment of sun-damaged skin.
FORUMSView All (29)
-chadi 1
Tue Jun 24 2025
error in switching on
E03: close shutter fault
Equipment: cynosure - apogee 5500
-Laser J
Wed Sep 27 2023
Elite MPX YAG head won't calibrate
I got an ELlite MPX. Alex works great, but the YAG won't calibrate successfully. The lamps are good, so wondering what else could cause this.
-Laser J
Mon Aug 08 2022
Dump error E16
I have an Elite ELMD with a dump error E16- dump always on. It is not the power supply causing this, since we have had it examined and it was not coding out other machines. What else could be causing this error? Any advice would be helpful. Josh@thelaseragent.com .
Equipment: Cynosure - Apogee Elite
[list]         [*] Twice as effective, twice as easy to use.         [*] Hair removal for all skin types. 755 nm Alexandrite for skin types I-IV; 1064 nm Nd:YAG for skin types V-VI and tanned skin.         [*] Pigmented lesions. The Apogee Elite’s short pulse durations provide effective treatment of pigmented lesions, age spots, freckles and sun spots.         [*] Facial and leg telangiectasias. Effective treatment for vessels up to 3 mm.         [*] Facial treatment for sun-damaged skin.         [*] Combination treatment visibly reduces redness and pigmentation, resulting in healthier, more radiant looking skin.         [*] Choose the wavelength that provides optimal results for the removal of unwanted hair.    [*] Pulse duration selectivity allows you to customize treatments according to your patients’ aesthetic needs.         [*] The Apogee Elite delivers high fluences from large spot sizes ensuring faster, more effective treatment.          [/list]
Laser TypeAlexandrite
Height41 in
Length 25 in
Weight180 lbs
Wavelength755 nm and 1064 nm
Width15 in
Laser: The Apogee Elite contains two laser systems: a 755 nm Alexandrite laser and a high powered 1064 nm Nd:YAG laser  Application: Hair removal, pigmented lesions, facial and leg telangiectasias, treatment of sun-damaged skin  Cooling SystemCold Air or Integrated Cooling  Pulse Width  - 755: adjustable 0.5 - 300    - 1064: adjustable 0.4 - 300    Repetition Rate    - 755: 2Hz    - 1064: 5Hz
