Bayer - HEMA-TEK 2000
by Bayer
Slide strainer
This stainer provides a continuous-feed loading platform that eliminates wasted time associated with batch staining methods. Correct first-time staining means less duplicated work. Pumps deliver fresh reagents in precise volume for every stain while the platen provides uniform stain from field-to-field and slide-to-slide with stain and buffer mixing accurately and uniformly. Slides are immediately available for viewing upon completion of staining, and the rinse reagent contains the optimal alcohol concentration for proper slide drying. Dials, located on front panel, allow for wide variation in stain intensities to suit individual needs. Stains 60 slides per hour. Uses disposable, prepackaged stain, buffer, and rinse solutions. Pilot light indicates when remaining solution is sufficient for only 20 slides. Main functional components are spiral conveyors and three peristaltic pumps. This stainer is simple to maintain.
0RepliesFri Apr 23 2021 | Is this device still supported? Is this device still supportedReply |
1ReplyMon Jun 03 2019 | glass slide out of time How do I put the gears or what do I do to get my slides going straight not crooked?Reply |
1ReplyMon Jan 09 2017 | replacement Platen part number The rinse buffer nipple broke off the platen, are replacement platens available Reply |
| Height | 7.5 in |
| Length | 17.1 in |
| Width | 18.5 in |
