Siemens - Somatom Volume Zoom
by Siemens
The Somatom Volume Zoom is a entry level 4 slice CT scanner that will make the multi-slice in CT imaging more accessible for your clinic. This CT scanner has been equipped with some of the features by Siemens that have already been tried and proven to work such as the CT³ Volume Scanning technique, the Siemens Lightning UFT detector array, the SureView image reconstruction algorithms and more.
0RepliesThu Oct 12 2017 | Siemens Sensation CT 4 part series – Part 4 Preventative Maintenance Siemens Sensation CT 4 part series – Part 4 Preventative MaintenanceReply |
0RepliesThu Oct 12 2017 | Siemens Sensation CT 4 part series – Part 3 Tube Installation Tips Siemens Sensation CT 4 part series – Part 3 Tube Installation TipsReply |
0RepliesThu Oct 12 2017 | Siemens Sensation CT 4 part series – Part 2 HV Troubleshooting Tips Siemens Sensation CT 4 part series – Part 2Reply |
[list] [*] Siemens CARE solutions [*] syngo user interface [*] 50ms rotation time [*] 1.5 slices/s image reconstruction time [*] 60kW generator [/list]
| Type (configuration) | Multislice |
| Slices | 4 |
| Maximum Scan Range | 157 cm |
| Gantry (Max. Clearance) | 70 cm |
| Image Display | 21 in |
| Patient Weight Capacity | 440 lbs |
