Datex Ohmeda - Tec 4
Vaporizer
The vaporizers are temperature and flow compensated. A single control dial, with a concentration scale calibrated in % of anesthetic agent. To prevent accidental displacement of the cotrol dial from the 'OFF' position to an 'ON', a release button is incorporated into the dial assembly. The Tec 4 can only be turned "ON' when the locking lever is turned to the 'LOCK' position. Liquid Capacity: Amount of anesthetic agent to fully charge the vaporizer=125ml.
0Replies11 years ago | service manual need to dismantal to free dial Reply |
[list] [*] Modern anesthetic designed for "out-of-circuit" use in continuous flow techniques of inhalation anesthesia [*] Built-in temperature-compensated and pressure-compensated capabilities [/list]
Flow Rate Range | 0.25 to 15 L/min |
Weight | 7.6 kg |
Concentration Range | 0 to 7 % |
Capacity (dry wick) - 135 cc Capacity (wet wick) - 100
