Draeger - Infinity Gamma XL
Compact and lightweightInfinity Gamma XL is a compact vital signs monitor that can operate as a standalone device or as part of the Infinity Network. It provides a full set of the most commonly used parameters for monitoring adult, pediatric and neonatal patients and is ideal for low- to mid-acuity care environments. Standard parameters include ECG, basic arrhythmia, Respiration, pulse rate, temperature, noninvasive blood pressure and SpO2 (Optional: Infinity® Masimo SET® SmartPod® with Masimo’s SpO2 algorithm, known for accuracy during low perfusion and most types of patient movement). The Gamma XL has an 8.4” (210mm) color screen and displays up to 4 channels. With Drager’s patented Pick and Go technology, the Gamma XL double as both a bedside monitor and transport monitor within the hospital. The seamless wired-to-wireless networking ensure data acquisition is consistent with no gaps or interruptions. While being used for transport, the Gamma XL can automatically store events and print them upon docking.
1Reply12 years ago | adapter cord We were looking for an ac power adapter that's compatible with the gamma and delta model and the cost of that cord. Reply |
1Reply13 years ago | Infinity Gamma XL We need this monitor, could you supply?Reply |
[list] [*] Eliminates the need for separate transport monitors [*] Compact and portable with Drager’s patented Pick and Go technology. [*] Standard parameters include ECG, basic arrhythmia, Respiration, pulse rate, temperature, noninvasive blood pressure and SpO2. [*] Designed with a scalable feature set that meets the needs of today’s mid-acuity care. [*] Supports a wireless card that offers enhanced security (WPA2) and Wi-Fi (820.11g) technology for wider bandwidth. [*] Works as a standalone device or connects to Infinity Network via Infinity Docking Station, DirectNet or wireless adapter for seamless wired to wireless networking [/list]
Height | 10 in |
Length | 7.5 in |
Weight | 12.7 lbs 14 lbs with external battery |
Width | 14.4 in |
ECG Displays up to 12 leads Available leads I, II, III, aVR, aVF, aVL, V, V+, (V, aVR aVF, aVL only with 5- and 6-lead sets, V+ only with 6-lead set), TruST® 12-lead with reduced lead-set (6-wire): I, II, III, aVL, aVR, aVF, dV1, V2, dV3, dV4, V5 and dV6 (indicated for adults and pediatrics).1 Measuring range 15 to 300 bpm (heart rate) Accuracy ± 2 bpm or ± 1% (whichever is greater) Frequency ranges Filter off: 0.05 to 40 Hz display; 0.05 to 125 Hz printer Monitoring filter: 0.5 to 40 Hz; ESU filter: 0.5 to 16 Hz QRS Detection Range: Amplitude 0.5 to 5 mV Duration Adult and pediatric: 70 to 120 msec Neonatal: 40 to 120 msec Alarms User-selectable upper and lower limits Pacer detection Leads: I, II or III (adult/pediatric) Amplitude: ± 2 to ± 700 mV Width (dp): 0.2 to 2.0 msec Accessories 3-, 5- or 6-lead electrode set ST (not intended for neonates): Available leads With 3-lead ST option: Choice of any 3 available leads With ARIES option: Up to 12 leads ST complex length 892 msec (-300 to +600 msec from fiducial point) Sample rate 225 samples/sec Frequency response 0.05 – 40 Hz Isoelectric measurement point: Measuring range Start of ECG complex to fiducial point Default QRS onset – 28 msec ST measurement point: Adjustment range Fiducial point to end of ECG complex Point default QRS offset +80 msec Update interval 15 sec, 1 normal beat required Resolution ± 0.1 mm Trends Graphical, tabular and graphical mini-trends INOP alarm Yes Upper and lower ST alarms ± 15 mm, ± 0.1 mm increments Duration of ST event to trigger alarm None, 15, 30, 45, 60 seconds Arrhythmia Detection: Adult and Pediatric Yes Neonatal No, only bradycardia is available as a low heart rate alarm in neonatal mode ARR Mode User Selectable; OFF, Basic or Advanced Basic ARR (standard) Asystole, ventricular fibrillation, ventricular tachycardia and artifact (ARR label displayed to register arrhythmia occurrence) Advanced ARR (option) Ventricular run, accelerated idioventricular rhythm, supra-ventricular tachycardia, couplet, bigeminy, tachycardia, bradycardia, pause and also supports PVC/min parameter output. Respiration: Sensing leads I, II (user-selectable) Measuring method Impedance pneumography Auxiliary current =10mA for any active electrode Detection threshold 0.15W to 4.0W in manual mode (user adjustment) 0.2W to 1.5W in auto mode (automatic adjustment) Measuring range 0 to 155 breaths per min Accuracy ± 1 breath/min or 2% of rate (whichever is greater) Apnea detection For neonatal and pediatric patients Alarms User-selectable upper and lower respiration rate
