American Imex - Interferential Stimulator
Interferential StimulatorThe true sine wave interferential device that utilizes a 4000Hz carrier frequency to send interferential signals deep in muscle tissue. The unit has a built in timer so patients know when their treatment is complete without having to watch the clock. Constant frequency settings range from 4-400 bps or you can utilize the auto sweep feature to sweep frequencies from 4-45, 8-150, or manually adjustable from 4-xx.
SERVICE COMPANIESView All Electrotherapy Companies
- Dual Channel True Interferential
- Wide Adjustable Beat Frequency
- AC Adapter
- Battery, Electrodes, Safety Leadwires, Carry Case
Height | 108 mm |
Interferential Current | YES |
Weight | 100 g without battery |
Width | 61.5 mm |
Channel: Dual, isolated between channels
Pulse amplitude: Adjustable 0-60mA peak into 500 Ω load each channel, constant
current
Carrier Frequency: 4000Hz fixed (CH1)
Modulating Frequency: 4004-4160Hz Adjustable (Ch2)
IF Frequency Mode: Constant Mode: 4-160 bps, adjustable Auto Sweep: 80-145 bps, 4-
45 bps, 4-Set bps.
Frequency Shift: 1/1 abrupt, 6/6 abrupt/ramped, 10/10 abrupt/ramped
Sweep Time: 15 seconds
Frequency Shift %: Frequncy shifts from 30% below set frequncy to 60% above and
return to 30% below set
Output Configuration: Quad polar (4 electrodes)
Wave form: Symmetrical balanced sine wave
Interference Pulse: 4-160 pbs, adjustable 4 bps/step
Pulse Duration: 125Μs fixed
Patient Compliance: Lock prevents the patient from changing fixed parameters
Patient Compliance: Shows the treatment times in hours.
Timer: 15, 30,minute selectable
LCD: Shows modes, bps rate, abrupt/ramp, timer, channels.
Max charge per pulse: 15 micro-coulombs maximum.
Power Source: 9-Volt DC adapter, 500mA or Alkaline
9 Volt battery.
Dimensions: 108mm(H) ×61.5mm(W) ×25mm(T).
Weight: 100grams (without battery).
