American Imex - Interspec IF II
Interferential and neuromuscular stimulation device.
Interspec IF-II™ Interferential / Neuromuscular Stimulator The Interspec IF-II is a digital interferential device that provides 6 interferential programs and a neuromuscular stimulation program. The Interspec IF-II features a post-op program with a continuous treatment timer for constant stimulation following surgery. The device has a patient lock out feature and preset programs for ease of setup. Once the programs are set, the patient then only has to turn on the power and increase the amplitude for treatment. The device will automatically shut off after the treatment cycle has been completed. Five preset interferential programs include a signal vector rotation program. A fully customizable program is also available. [i]*This item in not for resell in the US*[/i]
1Reply2 years ago | Replace a unit What is the cost for this unit? Reply |
SERVICE COMPANIESView All Electrotherapy Companies
- Dual Channel Interferential /Neuromuscular Combo Stimulator
- Post-Op Program Mode with Continuous Use Timer
- AC Adapter
- Battery, Electrodes, Safety Lead wires, Carry Case
Interferential Current | YES |
Neuromuscular Electrical Stimulation (NMES) | YES |
Channel: Dual Channel Interferential and Neuromuscular Stimulation Wave form: Symmetrical Square Wave Output: Adjustable 0-60mA peak into 500 Ω load each channel Carrier Frequency: Channel 1: 4000Hz fixed Modulating Frequency: Channel 2: 4010-4400 Hz Adjustable Power Source: 9 Volt AC adaptor or Alkaline Battery Program 1 Interferential High/Low Part 1: 100 Hz, Mode 6/6 Ramp, Time 20 Minutes Part 2: 20 Hz, Mode 6/6 Ramp, Time 20 Minutes Program 2 Interferential High 100 Hz, Mode 6/6 Ramp, Time 20 Minutes Program 3 Interferential High Continuous 100 Hz, Time Continuous Program 4 Neuromuscular NMES 70 Hz, 2 secs Ramp Up, 6 secs On Time, 12 secs Off Time, Time 10 Minutes Program 5 Interferential/ NMES Part 1: IF 100 Hz, Mode 6/6 Ramp, Time 20 Minutes Part 2: NMES 70 Hz, 2 secs Ramp Up, 6 secs On, 12 secs Off , Time 10 Minutes Program 6 Interferential Vectoring
