Baxter - Flo-Gard 6301
by Baxter
Dual-Channel IV pump
The Baxter Flo-Gard 6301 Infusion Pump is an all-purpose IV pump that uses standard IV administration sets from Baxter. The pump features automatic piggybacking, upstream and downstream occlusion detectors, air-in-line detection, automatic restart after occlusion clears and IV set free-flow protection.
Flo-Gard pumps are currently only serviced by Baxter in Latin America.
FORUMSView All (18)
-gjubra
Sat Jul 31 2021
Schematic Diagram
I was trying to troubleshoot a problem with the circuit board but I couldnt find the schematic diagrams for it - Any idea how to get my hands on the schematics? Thank youReply
-tmooreking_4725
Fri Feb 22 2019
F 38 Error Code
What does it mean?Reply
3
-Rainbow River An Hosp
Mon Dec 31 2018
F_42 error
This is for the pump I have been using for parts. I'm curious if an F_42 error would be easier to fix then the F_49 on the pump I am trying to fix.Reply
  • Configurable settings allow the pump to be custom-tailored to best suit the hospital’s needs
  • Safety clamp automatically occludes the tubing when the pump door is opened
  • Occlusion sensors detect both upstream and downstream restrictions
  • Sensitivity of the downstream occlusion sensors are selectable through the pump’s configuration
  • Volume-Time programming automatically calculates flow rate Easily replaceable fuse, battery, and power cord
  • Dual channel pump (Functions as two 6201’s in a single unit) with independent controls
  • Automatic Restart once occlusion clears
  • Automatic Piggybacking of secondary medications
  • Flow Check Occlusion
  • Alarm offers an in-line resistance display of incremental back pressure
  • Slide Clamp option offers an additional step to protect against inadvertent gravity-free flow
  • Flow Rate Calculation is automatic after volume and time are selected
  • Front Panel Lock-out protects against tampering
  • User-adjustable occlusion pressures
Volume to be Infused1 to 99.9 ml
Height11.4 in
Length 5.1 in
Weight17.9 lbs
Width13 in
