Baxter - Colleague 3
by Baxter
Colleague pumps are only available and supported outside the US, as of July 14, 2012.
The Baxter Colleague 3 Volumetric Infusion Pump can be utilized for continuous or intermittent delivery through clinically acceptable routes of administration, such as intravenous, intra-arterial, subcutaneous, epidural, or irrigation of fluid spaces applications. The Colleague triple channel pump’s battery has a 3 hours operating time at 100 mL/hr for all three channels (with fully charged new batteries). It takes 12 hours to recharge to 80% of capacity. An internal charge system recharges batteries whenever the device is connected to an AC outlet.            [i][b]Colleague pumps are only available and supported outside the US, as of July 14, 2012.[/b][/i]
FORUMSView All (4)
-Tyler S
11 years ago
Baxter Colleague 3 won't power on with AC or battery.
I have a Baxter Colleague 3 that will not power on. My original thought was that it needed a new fan because it made a strange noise when I plugged it in. I tested the fan with a power supply, and it ran smoothly. I also measured the fan output on the power supply board, and I got 13.92 V, which shouldn't be a problem. Does anyone know what the problem could be?
-Del Morden
11 years ago
Error Code 550:320:658:0000
Baxter Colleague 3 Error Code 550:320:658:0000???
-ricky
13 years ago
Battery changing
I need to know the procedure for changing the small lithium batteries please.
