Baxter - InfusOR
by Baxter
The Baxter (Bard) InfusOR is designed to aid the infusion of many intravenous agents during anesthetic procedures. The InfusOR is simple to use and drug delivery choices are easily selected and changed using front panel rotary switches. Baxter has ended service on this product. Please see one of the available 3rd party companies for service and/or sales.
1ReplyWed Jan 10 2024 | operator manual humidity specs Equipment: Baxter - InfusOR Reply |
1ReplyThu Oct 21 2021 | Occlusion I'm not sure how to perform the Occlusion force 8 lb +- 1 on this unit and I can't view the PM instructions on MedWrench..Do you have instructions for this step in the inspection process?Reply |
2RepliesFri Jul 19 2019 | EOS error pump constantly states EOS and alarms???Reply |
[list] [*] Designed to aid in many intravenous agents given during anesthetic procedures [*] Provides for the convenient delivery of narcotics, muscle relaxants, vasoactives and other drugs routinely given during anesthesia [*] Easy to use and set up [*] Drug delivery choices are easily selected and changed using front panel rotary switches [/list]
| Flow Rate Range | 0 to 600 ml/h |
| Weight | 2 lbs |
| Flow Accuracy | 3 % |
| Infusion Pump Type | General-Purpose |
