CareFusion - Alaris MedSystem III 2863
by CareFusion
The Alaris IVAC Medsystem III 2863 is an infusion pump that can be programmed to deliver at a specified rate or over a specific period of time.
-lifepakguy
8 years ago
Battery capacity and battery charge current
I have a MSIII model 2863 with a customer complaining of short battery life. The device charge current is 180mA, which is in spec according to the manual. Batteries charged 24 hours in the device have a very low capacity. Testing the batteries in a Cadex analyzer with charge current set to 180mA, and the batteries never reach full charge. Increasing charge current to 500mA increases battery capacity to 100%. I've found this to be the case on numerous batteries, and they are all R&D. Any ideas?Reply
4
-John White
9 years ago
Host system requirements for the MEDSYTEM III Field Maintenance Software?
What are the host system requirements for the MED SYstem III Field Maintenance Software that is used to support the MEDSYSTEM III Infusion Pumps?
Volume to be Infused0.1 to 999 ml
Height7.87 in
Length 2.1 in
Weight5.1 lbs
Flow Accuracy5 %
KVO Range0.1 to 20 ml/h
Width6 in
