CareFusion - Alaris MedSystem III 2865
by CareFusion
The Alaris IVAC Medsystem III 2865 is an infusion pump that can be programmed to deliver at a specified rate or over a specific period of time.
FORUMSView All (14)
-Tiptonems
Mon Jan 11 2021
Calibration
Hello I am looking to see if anyone could share a picture of the calibration parts that are used with the medsystem. I understand that there is need to modify a cassette, there are some weights and another pressure setup that need to be checked. I have been trying to figure out where to start however because this pump is not supported by the manufacturer it is difficult to get answers. Any help would be appreciated Reply
-Tiptonems
Wed Jan 08 2020
Pump testing
Hoping to get some help with this: I am working on calibrating a 2865. Does anyone have a picture oh how they created the modified cassette for pressure calibration? Or is there a part number that I can just buy. Also looking for the patient fluid occlusion cassette Reply
5
-DiegoB
Tue Apr 30 2019
Help maintenance service
I just got one, and suddenly a text pop out maintenance service required and I don even have 6 months with the device Reply
VIDEOS
Channel Error ...
Alaris MedSystem III Overview...
[list]  [*] Multi-channel infusion pump  [*] Six selectable device types: general purpose, neonatal, controller pressure, O.R., general purpose II, and O.R. II  [*] Drug dose calculator  [/list]
Volume to be Infused0.1 to 999 ml
Height7.9 in
Length 2.1 in
Flow Rate Range0.1 to 999 ml/h
Weight5.1 lbs
Flow Accuracy5 %
KVO Range0.1 to 20 ml/h
Width6 in
Battery Capacity: Minimum 6 hours with all three channels at 125 mL/hr     Power Requirements: 6 watts AC power. 110/120 VAC, 60 Hz
