CareFusion - Alaris Imed 2-TX
by CareFusion
PC-2TX infusion pump is a dual-channel infusion system designed to help improve clinician efficiency and to provide great value in a two-chanel pump.
The Gemini PC-2TX infusion pump is a dual-channel infusion system designed to help improve clinician efficiency and to provide great value in a two-channel pump.
FORUMSView All (3)
-AIV
Thu Jun 28 2012
CareFusion Alaris System to be Made Compatible with Epic's EMR
Hey guys, do you know that the Alaris infusion pump systems will be integrated with Epic's EMR? Here's the full the story: http://www.aiv-inc.com/iv-pump-news/carefusion-alaris-system-to-be-made-compatible-with-epic-s-emr.html
-AIV
Mon Jun 04 2012
Alaris Pump is FIPS140-2 Accredited
Hey, did you know that Alaris infusion systems were the first to be granted with the new FIPS 140-2. This is a required data encryption certification required for infusion pumps operating in US Dept. of Veterans Affair hospitals? Check the news story here: http://www.aiv-inc.com/iv-pump-news/alaris-infusion-pump-system-now-fips-140-2-accredited.html
-AlanHopkin
Sat Nov 19 2011
Gemini PC-2TX computer control
I am looking to use a host computer to control an Alaris Imed PC-2TX.  Anyone have experience with this? Anyone know where I can find the Alaris Medical Systems Programmer's Guide?
[list]         [*] Backlit center display         [*] Rapid Rate, On-Line Titration         [*] Infusion Rate Profiling Options         [*] Panel Lock         [*] Pressure History         [*] Drug Dose Calculator         [*] Programmable Start Time         [*] Multi Dose         [*] Volume/Time Dosing         [/list]
Volume to be Infused0.1 to 9999 ml
KVO Rate1 ml/h
Weight18.5 lbs
