CareFusion - Alaris Imed Gemini PC1
by CareFusion
A single channel volumetric infusion pump and controller.
The Imed Gemini PC-1 is a single-channel, linear peristaltic volumetric infusion device with ultrasonic air detection, which can be operated either as a controller or as a positive-pressure pump. Secondary (piggyback) medications can be automatically infused at rates and volumes independent of the primary infusion parameters, with automatic changeover to the primary at the conclusion of the secondary infusion. The PC-1 also has a 20-step program feature, called the VersaTaper mode, which allows stepped program of sequential rates and volumes for TPN or antibiotic infusion. The pump can be configured as a Micropump (rates from 0.1-99.9 ml/hr.) or as a Macro pump (1-999 ml/hr). An RS-232 port is included and allows the pump to serve either as the control or slave unit for computer monitoring.
The PC-1 delivers precise infusion rates, enables rapid rate adjustments without interrupting the flow, and include a panel lock safety feature that prevents inadvertent changes to the infusion program.
FORUMSView All (14)
-Sudarshan Anbazhagan
5 years ago
Calibrate the VTBI for Generic IV Set
I am planing to use this with an Generic IV set that I get locally. it works all fine except there is an small error of 0.5 to 1 ml per 5ml of VTBI. can anyone guide me on how to calibrate this error ? I have my own set of common test bench and tools needed for this.Reply
2
-ttb447
6 years ago
Imed Gemini PC-1 Door/AIL Error
I have been getting this error on several pumps. When you open the door, the pump turns on. This seems to often be coupled with the equipment saying the door/Flo-Stop is open even when the door is closed. I tried changing the AIL and it seems to not address the issue. Ideas?Reply
2
-mferguson
7 years ago
service manual
KVO Rate1 ml/h
Weight11.3 lbs
