Baxter - Flo-Gard 6300
by Baxter
The Baxter Flo-Fard Dual Channel Volumetric Infusion Pump can deliver a wide variety of fluids over a broad range of infusion rates. Flo-Gard pumps are currently only serviced by Baxter in Latin America.
3RepliesInvalid Date | Common Failure F-68 I have a double fluid pump and when I plug it in, an error comes up saying Common Failure F-68. Please, can you tell me what this means and how to resolve this problem? We need the pump. Reply |
1ReplyInvalid Date | F-22 on a Baxter 6300 Have a Baxter 6300 that I changed the batteries in and set to factory specs. Worked great for about one month and then gave an F-22 error on both sides. Any ideas? Reply |
0RepliesInvalid Date | Pump Failure Need to look at the manual Reply |
[list] [*] Operates similarly to Baxter 6200 [*] Wall or built in battery operation [*] Uses standard Baxter IV administration sets [*] All digital controls [*] 0-999 ml infusion rate [*] 0-9999 total infusion volume [*] Built in IV pole clamp [*] All digital display [*] Digital alarm display [/list]
| Volume to be Infused | 0 to 9999 ml |
| Height | 11.4 in |
| Length | 8.3 in |
| Weight | 18 lbs |
| Infusion Pump Type | General-Purpose |
| Width | 13 in |
