Physio-Control - LifePak 1000
by Physio-Control
Defibrillator
The LIFEPAK 1000 defibrillator is an advanced platform designed to provide the best resuscitation option now and in the future. Field upgradeable therapies focused on enhancing patient outcomes will continually build on the LIFEPAK 1000 defibrillation platform. The 1000 is compatible with other Medtronic products, services and data solutions across the full spectrum of care, from the field to the hospital. With the touch of a button you can assess battery readiness at a moment’s notice, thanks to a visible and accessible gauge. The advanced battery also performs sophisticated communications directly with the device so you always know the battery’s condition.
-Eveij
Tue Feb 11 2020
Service code
Does anyone know service code (4 digits) for lifepak 1000 and if it is possible to change language there ??Reply
  • Contains CPRMax Technology which increases CPR hand on time from 55% to 90% in the first 8 minutes CPRMax Technology allows the LP-1000 to charge while CPR is being done; thereby reducing the time that CPR must be stopped due to the AED.
  • Heavy duty battery can deliver up to 440 separate 200 joule shocks.
  • Large bright screen with ECG display.
  • Can convert AED to manual mode with one touch of a button.
Height3.4 in
Length 10.9 in
Weight7.1 lbs
Defibrillator TypeExternal, Automated (AED)
Width9.2 in
  • Charge Time:With new, nonrechargeable battery pack; 200 joules in less than 7 seconds (360 joules in less than 12 seconds).
  • Infant/Child Reduced Energy Defibrillation Electrodes:Reduces selected energy by a factor of 4. Intended for use only with children up to 8 years of age or 25 kg (55 lbs)
  • Electrical Protection: Input protected against high voltage defibrillator pulses per IEC 60601-1.
NEWSView All
Physio-Control Launches Voluntary Field Action for LIFEPAK 1000 Defibrillator
Physio-Control Launches Voluntary Field Action for LIFEPAK 1000...
Physio-Control has announced a voluntary field action for the LIFEPAK 1000 defibrillator due to reported instances where the device has shut down unexpectedly during patient treatment.
FDA AlertsView All
Class 1 Recall: Physio-Control Inc. Recalls Defibrillation...
Class 1 Recall: Physio-Control Inc. Recalls LIFEPAK 1000...
Physio-Control is recalling the LIFEPAK 1000 due to an electrical issue which may cause the device to shut down unexpectedly during patient treatment.
