GE HealthCare - Corometrics 250cx Series
by GE HealthCare
The Corometrics 250cx Series monitor allows you to address the monitoring needs for both the mother and the fetus.
The CorometricsTM 250cx Series maternal/fetal monitoring system is a full antepartum/intrapartum fetal monitor that includes innovative features that helps you deliver a high quality birthing experience and enhanced patient care. It monitors uterine and fetal activity including fetal heart rate, and has enhanced maternal monitoring features including temperature, oxygen saturation, ECG and non-invasive blood pressure.
FORUMSView All (17)
-wheelzupz28
Thu Apr 23 2026
Recorder board
I replaced the print head, cable and recorder board. There’s a voltage adjustment using TP1 and TP2. These points are not labeled on the board and there’s no diagram in the service manual. Does anybody know where the test points are?
-Mike Mike
Tue Oct 15 2024
Record/Print Speed
I have noticed the mm/s is not adjustable nor does the general setup save the cm/min on restart. What I found out so far is the cm/min can be set from 1 to 3 cm/min. The "paper advance" button is set at 40 cm/min. My goal is to change the default settings to either 50 mm/s or 3 cm/min without having to change the general setup on restart. Trying to find a solution for this goal/problem.
-Mr.Argo
Thu Sep 05 2024
printer eject button
need to find part number for printer eject button
Equipment: GE HealthCare - Corometrics 250cx Series
  • GE-exclusive Smart BP - delays blood pressure measurement during contractions
  • Provides the light you need to see clearly
  • Allows for exceptional pick-up and minimal repositioning
  • Minimizes monitor interactions
Height6.7 in
Length 17.3 in
Weight24 lbs
Width16.5 in
