CareFusion - Nicolet VersaLab APM
by CareFusion
The Nicolet VersaLab APM is a portable, economical antepartum monitor (APM) for performing non-stress tests. It is the smallest and lightest APM available featuring a built-in printer.
2RepliesWed Aug 30 2023 | Service manual Does anyone have a service manual for this Natus Nicolet verslab apm? Equipment: Natus Nicolet versalab apm Reply |
1ReplyFri Mar 08 2019 | REQUEST FOR SERVICE MANUAL Hello every one, i will be glad if someone can assist me with the technical manual for HOSPITEX ECG 1220 MACHINE and VIASYS NICOLET VERSALAB APM FHR machine. my email address is addaijeffrey32@gmail.com Thanks.Reply |
0RepliesWed Mar 22 2017 | SERVICE MANUAL VERSASLAB APM SERVICE MANUAL VERSASLAB APMReply |
| Height | 31 cm |
| Length | 23 cm |
| Weight | 4.1 lbs |
| Width | 7.3 cm |
Doppler Technology: Continuous Wave (CW) unfocused 2.0 MHz probe Battery Type: 7.2V NiMH, 6x4/5A, rechargeable Full Charge Life: 3 hours Battery Recharge Time: 3 hours Operating Ambient Temperature: 10º C - 40º C (50º F - 104º F) Graphic Display: 320 x 240 pixel color or b/w Printer: Thermal, 104 mm print width, 832 dots, 8 dots/mm Printer Paper: Roll, 112 mm wide, thermal Print Speed: 1 cm/minute, 2 cm/minute and 3 cm/minute Speakers: (2) 66 mm, 8½, 0.5 watt Audio Output: 0.5 watt per channel Recharger, INPUT: 100 - 250 VAC, 50/60 Hz, Model WSL170M Recharger, OUTPUT: 7vDC @ 3.5 A Model WSL170M Safety Standards: IEC 601-1, EN60601-1, EN60601-1-2, IEC 60601-2-37 Classification: Internally powered equipment Classification of Protection Against Electrical Shock: Type B
