CareFusion - Nicolet VersaLab APM2
by CareFusion
The Nicolet VersaLab APM2 is a portable, economical antepartum monitor (APM) for performing non-stress tests. It is the smallest and lightest APM available featuring a built-in printer. It allows you to perform non-stress testing on one or two fetuses simultaneously.
0RepliesFri Oct 11 2013 | problems with remote event marker I have a unit which will not post an event via the pendant, but will with the onboard button. I checked the pendant all the way to the interconnect board to the logic board. I am not sure where the two buttons combine because I do not have a service manual.. Has anyone else seen this problem? Everything else seems to be working very well... I was expecting to find a bad pendant or jack.. but these are both good. I actually am able to trace the circuit back to the interconnect of the two circuit boards bridge connector. Reply |
| Weight | 4.1 lbs |
Doppler technology: Continuous Wave (CW) unfocused 2.0 MHz probe Battery type: 7.2V NiMH, 6x4/5A, rechargeable Full charge life: 3 hours. Battery recharge time: 3 hours. Operating ambient temperature: 10º C - 40º C (50º F - 104º F) Graphic display: 320 x 240 pixel color or b/w Printer: Thermal, 104 mm print width, 832 dots, 8 dots/mm Printer paper: roll, 112 mm wide, thermal Print speed: 1 cm/minute, 2 cm/minute and 3 cm/minute Speakers: (2) 66 mm, 8½, 0.5 watt Audio output: 0.5 watt per channel Recharger, input: 100 - 250 VAC, 50/60 Hz, Model WSL170M Recharger, output: 7vDC @ 3.5 A Model WSL170M Safety standards: IEC 601-1, EN60601-1, EN60601-1-2, IEC 60601-2-37 Classification: Internally powered equipment Classification of protection against electrical shock: Type B
