Edan - Cadence II
by Edan
Lightweight, space-saving fetal monitor.
Cadence II is a lightweight, space-saving fetal monitor. The external and internal monitoring parameters ensure it can be used up to and during the second stage labor. It also can be connected to the MFM-CNS obstetrical central station to construct central monitoring system.
[list]   [*] Offers the economics of a low cost unit with many of the high end features needed to care for your patients   [*] Great for use in CPT code 59025 (Fetal non-stress test)   [*] Ideal for the private practice or small clinic   [*] Lightweight, space-saving, easy operation   [*] Folding up 5 inch screen   [*] Nine elements high sensitive probe   [*] Wide range of applying voltage (100-250V)   [*] Optional Dual FHR monitoring   [*] Automatic Fetal Movement Detection   [*] Built-in network/PC connecting interface   [*] Insight software for data recording and displaying on a standard PC   [*] Optional rechargeable Lithium battery    [/list]
Height330 mm
Length 270 mm
Weight3.5 kg
Width100 mm
