SPO Medical - 5500
by SPO Medical
Pulse Oximeter
It has never been easier to access the essential information to successfully manage your oxygen saturation level. With our sophisticated sopt-check oximeter you can go about your daily activities with piece of mind. The PulseOx 5500™ is the world's first spot check monitor for blood oxygen saturation and heart rate to use reflectance pulse oximetry (RPO). The PulseOx 5500™ uses SPO Medical's patented technology to provide a medical device which can be used as often as needed and is less expensive to operate than any other device available.
-Xeno
7 months ago
manuals
I need an instruction manual
Equipment: SPO Medical 5500
SERVICE COMPANIESView All Pulse Oximeter Companies
  • FDA Approved for Accuracy
  • Weak Signal Indicator to assist in obtaining a strong reading
  • Can be used outdoors in many conditions, including high altitudes, at high and low temperatures, and even in the dark.
  • Ideal for home asthma monitoring requirements.
  • Soft rubber boot sensor keeps it in place even while you are in motion.
  • Battery Life Indicator
  • Superior Battery Life (1000 hours)
  • Digital LCD display for SpO2 and pulse rate with BACKLIGHT
Weight1.8 oz
Operating Life1000 hr
  • Weight: 1.8 Oz. (50 Grams) including Battery
  • Lanyard Cord
  • 3.6v Lithium Battery 1/2 AA Size
