CareFusion - Alaris Signature Gold 7130
by CareFusion
The Alaris IVAC Signature Gold 7130 Infusion Pump is a single channel volumetric infusion pump that allows independent programming on both sides. It can be used for general IV infusions, antibiotics, blood infusions, enteral infusions, TPN and hyperalimentation, and lipids. Monitoring options provide increased awareness of occlusion detection and battery charge condition. Dual-rate piggyback function and panel lock. A multi-step program function allows a sequential program to deliver up to nine rates and volumes; can also be programmed using volume and time. Multiple infusions can be preprogrammed over a period of up to 24 hours; delay start and loading dose features. Computer interface for remote monitoring. Rotating pole clamp for pole or bed-rail mounting. Drug-specific dose rates can be calculated by selecting a drug name, which will then display on the screen. Recommended for epidural infusions. Optional flow sensor.
3Replies7 years ago | instrument malfunction error Can anyone tell me how to correct and reset this unit? ThanksReply |
2Replies9 years ago | primary setups In December 2016 Care fusion is going to stop making these setups. Has anyone heard of a third party going to make these? We are trying to buy new pumps, but someone said that the setups will be remanufactured by a third party. Has anyone out there heard anything? Reply |
1Reply10 years ago | Red light and alarm on power uo and no display Went I arrived at site powered 7130 up and had no display,red alarm light next to "run/hold" and audible alarm. Without display very difficult to troubleshoot. No visible signs of abuse (dropped unit, etc). opened unit and verified cables to displays are connected. Any ideas? Display board my only thought...Mike Reply |
[list] [*] Battery Depleted [*] Channel Malfunction [*] Computer Link Failure [*] Flow Sensor Unplugged [*] Hold Time Exceeded [*] Instrument Malfunction [*] Key stuck [*] Latch Open [*] No Upstream Flow Detected [*] Occlusion Downstream [*] Occlusion Upstream [/list]
Volume to be Infused | 1 to 9999 ml |
Height | 8.6 in |
Length | 5 in |
Flow Rate Range | 0.1 to 999.9 ml/h |
Weight | 6.85 lbs |
Infusion Pump Type | General-Purpose |
KVO Range | 0.1 to 20 ml/h |
Width | 7.7 in |
