CareFusion - Alaris Signature Gold 7230
by CareFusion
Dual-channel infusion pump
The Alaris IVAC Signature Gold 7230 Infusion Pump is a dual-channel device with independent programming on each channel. It can be used for general IV infusions, antibiotics, blood infusions, enteral infusions, TPN and hyperalimentation, and lipids. Monitoring options provide increased awareness of occlusion detection and battery charge condition. Dual-rate piggyback function and panel lock.
A multi-step program function allows a sequential program to deliver up to nine rates and volumes; can also be programmed using volume and time. Multiple infusions can be preprogrammed over a period of up to 24 hours; delay start and loading dose features. Computer interface for remote monitoring. Rotating pole clamp for pole or bed-rail mounting. Drug-specific dose rates can be calculated by selecting a drug name, which will then display on the screen. Recommended for epidural infusions.
Formerly known as the IVAC Signature 7200.
1ReplySat Sep 26 2015 | alrais gold 7230 On a Alrais 7230 IV Pump how is the mode changed from NICU to a normal adult setting? Reply |
1ReplyTue Aug 16 2011 | Alaris Signature Gold 7230 Do you carry iv infusion sets for the Alaris Signature Gold 7230Reply |
| Volume to be Infused | 1 to 999.9 ml |
| Height | 8.6 in |
| Length | 5 in |
| Flow Rate Range | 0.1 to 999.9 ml/h |
| Weight | 8.4 lbs |
| Infusion Pump Type | General-Purpose |
| Width | 10.5 in |
