CareFusion - Alaris Imed Gemini PC 2
Dual-Channel Infusion Pump.The Alaris Imed Gemini PC-2 is an IV therapy system that operates as a stand-alone instrument with no computer interface. It controls the infusion and a host computer monitors pump operation. The IMED Gemini PC-2 is a dual channel volumetric infusion pump and controller which provides accurate and automatic infusion of intravenous drugs and fluids.
FORUMSView All (7)
2Replies8 years ago | Set compatibility Will infusion sets for the Alaris PC pump work in the Gemini pumps? I know some are compatible, but want to know if there are limitations. Thanks! Reply |
2Replies8 years ago | imed gemini pc-2 I would like to ask for the exact infusion tubing used exclusively in this kind of infusion pump. A clear picture of the original infusion set for imed gemini pc-2 would really be appreciated. If you may, you can email me here: elvekhadine@yahoo.com. Thank you. I need the info as soonest possible. Reply |
2Replies9 years ago | after a new battery After i install a new batery i still receive a 704 error. has anyone delt with this problem and if so what was your solution? Reply |
[list] [*] Dual Channel Delivery [*] Dose Rate Calculator; Delayed [*] Anesthesia Mode [*] Alarm Audio Profiles [*] Pump/Controller Mode [*] Micro, Macro and Universal Rate Modes [*] "10 PSI" Mode [/list]
Volume to be Infused | 0 to 999 ml |
Flow Rate Range | 0 to 999 ml/h |
Weight | 19 lbs |
Infusion Pump Type | General-Purpose |
KVO Range | 0 to 999 ml/h |
