CareFusion - Alaris Imed Gemini PC 4
Four Channel Volumetric Infusion PumpThe IMED Gemini PC-4 is a four channel volumetric infusion pump and controller which provides accurate and automatic infusion of intravascular drugs, fluids, whole blood and packed red blood cells.
0Replies12 years ago | CareFusion Alaris System to be Made Compatible with Epic's EMR Hey guys, do you know that the Alaris infusion pump systems will be integrated with Epic's EMR? Here's the full the story: http://www.aiv-inc.com/iv-pump-news/carefusion-alaris-system-to-be-made-compatible-with-epic-s-emr.html Reply |
Volume to be Infused | 0.1 to 9999 ml |
KVO Rate | 1 ml/h if set rate is 1 ml/hr or above; or set rate, if rate is 0.9 ml/hr or below |
Weight | 26.5 lbs |
Infusion Pump Type | General-Purpose |
