Smiths Medical - Cadd Prizm 6100 & 6101
by Smiths Medical
The PCA mode is designed for therapies that require continuous patient-controlled delivery or a combination of the two.
The CADD PRIZM 6100 can function on four distinct modes: PCA, continuous, TPN, and intermittent. The continuous mode is designed to deliver infusions at a constant, programmed rate. The TPN allows for the delivery of nutritional solutions or other fluids with optional tapering. The intermittent mode permits the infusion of specific volumes at regular pre-set times. The CADD Prizm 6100 has a single therapy feature and has an integral data port which can be used as an interface for a printer, as a remote dose cord input or as a modem for communications.
0RepliesSat Mar 27 2021 | Error code 10040 Does anybody know what error code 10040 is referencing to?Reply |
0RepliesThu Jan 21 2021 | clinician bolus codes What are the Clinician Bolus Codes and all other codes for this deviceReply |
1ReplyTue Feb 07 2017 | error allarm One of our pumps keeps alarming in a patient setting. it states "delivery too slow, external power source must be connected. patient states it alarmed the last two nights even with everything plugged in battery, pump and adaptor. Reply |
| Volume to be Infused | 10 to 9990 ml |
| Height | 5.6 in |
| Length | 1.7 in |
| KVO Rate | 5 ml/h |
| Flow Accuracy | 6 % |
| Infusion Pump Type | Ambulatory |
| KVO Range | 0 to 10 ml/h |
| Width | 4.1 in |
