CareFusion - Bird 8400ST & STI
by CareFusion
The Bird 8400 STI ventilator is a microprocessor controlled volume ventilator for adult applications with pressure-support ventilation capability.
1Reply12 years ago | Changing from volume control to pressure control Hello, On the Bird 8400 STi PC VAPS, there is a button to change from the standard volume control, to pressure control. The pressure control is easy to turn on by pressing this button, but I can not seem to turn it off again in order to return to the standard volume control. Any help would be greatly appreciated. Thank you Reply |
[list] [*] Familiar knob technology [*] Easy to operate [*] Full range of ventilator modalities [*] Designed for use in acute and sub-acute settings [*] Pressure control [*] Flow support [/list]
Height | 9 in |
Length | 13.5 in |
Weight | 32 lbs |
Width | 16 in |
