Newport Medical - HT50
The Newport HT50 Ventilator is the value leader in ventilatory care.With its rugged construction, easy trigger sensitivity, and fast re-charge from AC or external DC, the HT50 Ventilator is ideally suited for extended care, transport, hospital and homecare applications. This is the ventilator you've been waiting for - compact, lightweight, unsurpassed reliability, and self contained. Its comprehensive, versatile features meet the demands of almost any healthcare setting. Suitable for both pediatric (10kg) and adult patients for invasive or non-invasive ventilation, it's easy to use and inexpensive to maintain.
FORUMSView All (10)
4Replies3 years ago | High pressure Oxygen venturi malfunction I have had these vents on a back shelf but have pulled them out for the pandemic. I have realized that when I hook up the high pressure oxygen venturi Blender that no oxygen is being delivered. Perhaps they were installed wrong? I have used giving oxygen the other method explained in the manual but wondering how I can get the High pressure system to work. Does anyone have an installation guide for these? Any other advice?Reply |
4Replies8 years ago | Volume Factor Calibration Cannot get this measurement in range. It just stays at 70 +/- 5. Any ideas? Reply |
2Replies8 years ago | How do you reset service needed Replaced pump assy running 24 hour burn in now calibration after that How do you reset service needed message Reply |
[list] [*] Volume or Pressure Control Ventilation [*] Invasive or Non-Invasive Ventilation [*] Pressure Support [*] PEEP/CPAP, Built-in [*] Comprehensive Alarms/Monitoring [*] Internal Battery, long lasting with fast recharge [*] Unique Gas Delivery System Requires No External Air Compressor [*] Optional Air/Oxygen Mixer for high pressure 0.21-1.00 [*] Optional Blending Bag for Low Flow Systems [/list]
FDA AlertsView All
Class I Recall: Flight Medical V24-00400-29 Cable for Newport...
The recalled cable may cause an electrical shortage that can cause Newport HT50 ventilators manufactured prior to 2007 to shutdown unexpectedly. Download
