Newport Medical - Breeze E-150
by Newport Medical
Compact respiratory ventilator
The Newport Breeze is a compact respiratory ventilator that is accurate for tiny neonates and pediatrics, while delivering the flow range for adults. This ventilator separates the spontaneous flow system from the mechanical flow system, called 'DuoFlow'. The Breeze offers pressure or volume ventilation packaged with comprehensive alarms. This critical care vent is compact at less than 12 inches square.
-2015greg
7 years ago
gas mixer
i am looking for the overhaul kit for the gas mixer.Reply
2
-FrankD
12 years ago
BREEZE E-150 OP MANUAL
Can anyone help me on how to get a user manual for this ventilator? Any link? Thank you
[list]  [*] DuoFlow System - The Breeze separates the spontaneous flow system from the mechanical flow system. We call this 'DuoFlow'. The DuoFlow system allows you to customize the pressure wave pattern of the mechanical breath in order to meet time constant restraints, and then tailor the spontaneous flowrate for maximum patient comfort and minimum work of breathing.  [*] Comprehensive Alarms - The alarms are simple to set using the high and low control knobs and easy to read in the back-lit digital display.  [*] Compact Size - Less than 12 inches square, the Breeze fits into small areas where space is limited.  [*] Built-In Battery Back-Up - The E150's emergency back up power (for up to one hour) is essential for added safety in busy hospitals.  [/list]
