Zimmer - ATS 2000
by Zimmer
Tourniquet
The Zimmer ATS 2000 is the next generation from the ATS 1500 tourniquet system. The Zimmer ATS 2000 is a dual pump system that allows for Bier Block procedures. Feel free to inquire about Zimmer, Scanmed, and Expressaire tourniquet cuffs and hoses. Single & Dual Port Options: All cuff styles are available in both single and dual port configurations, allowing for use with any A.T.S. tourniquet regulator. Single port cuffs for use with the A.T.S. 750 and A.T.S. 1200 Tourniquet Systems. Dual port and Bier Block cuffs for use with A.T.S. 1500 and 2000 Tourniquet System.
0Replies2 months ago | CAL FAIL - Unit will not enter Cal mode Unit reads cal fail on both sides. We have already checked batteries, jumper, wire to power supply and fuse. We cannot get the unit to enter cal mode on startup (holding both + and - buttons on the Second Cuff pressure adjustment while powering on). The unit goes through its self-test while powering on, then displays the failure. As background, the error message first appeared right after we had begun a calibration on the unit. We have been unable to get the unit to do anything else since.Reply |
1Reply2 months ago | CAL FAIL - Unit will not enter Cal mode Unit reads cal fail on both sides. We have already checked batteries, jumper, wire to power supply and fuse. We cannot get the unit to enter cal mode on startup (holding both + and - buttons on the Second Cuff pressure adjustment while powering on). The unit goes through its self-test while powering on, then displays the failure. As background, the error message first appeared right after we had begun a calibration on the unit. We have been unable to get the unit to do anything else since.Reply |
1Reply6 months ago | ERROR CODE AMP FAIL Dear All , I have this ZIMMER - ATS 2000 im getting this ERROR CODE AMP FAIL. I did all the measurements didn't found something weird. Batteries are ok . Any suggestion. Equipment: Zimmer - ATS 2000 Reply |
