Zimmer - ATS 750
by Zimmer
Tourniquet
The Zimmer ATS 750 Automatic Tourniquet is a lightweight unit and very user friendly. It uses ambient air instead of using nitrogen tanks. The microprocessor controls provide accuracy and speed. The ATS 750 can be used on the countertop or with a pole mount. This unit is used.
0Repliesa year ago | Black cube component in the circuit board We have a faulty tourniquet which we're trying to fix and after testing we are suspicious of a black cube that we don't really know what it is or does. We are searching all over but nothing comes up. The box has the following printed in the top: P TSD-1060 M 9932 Does anyone know something?Reply |
2Repliesa year ago | ATS failure Hi there! So, I have a trouble with my ATS 750. When I try to use it (plugged) there's no function at all -not the display, neither the pressure- but a little gasp-like sound. When doing the maintainance test, the second one -Cr14- I have no volts reading. Have anyone else had a trouble like this, or any guess to get te solution?Reply |
1Reply6 years ago | AMP FAIL What causes this?Reply |
