Digirad - 2020tc Imager
by Digirad
The 2020tc Single-Head Imager is a compact, lightweight, solid-state gamma camera that is designed to offer maximum clinical versatility, convenience and flexibility virtually anywhere you need to perform planar and dynamic imaging procedures for small or large organ studies - anywhere within your facility.
Performs a wide range of imaging studies, including thyroid imaging, static bone scans, brain flow, renography, hepatobiliary, gastric emptying, sentinel node imaging, scintimammography, and cardiac.
1Reply2 years ago | Digirad 2020tc Arm not moving Hi All, Having an issue with the arm not moving up/down. I can hear the motor moving but nothing moves. I don't have the service manual so I don't know where to start. Any help/direction will be aprreciated.Reply |
1Reply3 years ago | Chiller replacement Hi Everyone, Looking for some instructions in how to replace the chiller for this system. I don't have the service manual, would highly appreciate it if there's one around. Thank you, JihadReply |
2Replies10 years ago | Manual Needed I need a second hand Acquisition/Processing Operators Manual for the 2020tc single-headed camera. What options do I have to obtain one? Reply |
Crystal Thickness | 6 mm |
Power Requirements | 120 VAC |
Weight | 401 lbs |
Detector Geometry | Single-head |
SPECT/CT Module | 0 |
Detector Material | Other digital material |
Gamma Camera Type | Non-SPECT |
Gantry Configuration | Open |
