GE HealthCare - Infinia Hawkeye 4
by GE HealthCare
All-purpose dual-detector SPECT/CT system available in a 3/8- or 1-inch configuration, and the free-geometry gantry design enables both 180° and 90° detector orientations for high scanning efficiency.
3RepliesWed Jul 10 2024 | Infinia Hawkeye 4 Error 70. Gantry will not move. Any ideas? Reply |
1ReplyThu Nov 02 2023 | COR Correction File why my SPECT could not find the COR correction file? Reply |
6RepliesThu Apr 29 2021 | Error # 157 gantry error Hi All I am having an intermittent error #157 that comes at the end of the scan and while the tech is getting the patient out of the bed. Anyone had this error before? I checked all the cables from the SEM to motor drivers, all good. Is there anything else that I am missing? Thank youReply |
| Crystal Thickness | 9.5 mm - 3/8 in or 25.4 mm - 1 in |
| Slices | 4 |
| Power Requirements | 208 VAC |
| Weight | 6392 lbs |
| Detector Geometry | Dual-head variable angle |
| SPECT/CT Module | 1 Standard |
| Detector Material | Sodium Iodide |
| Gamma Camera Type | SPECT |
| Gantry Configuration | Variable |
| Patient Weight Capacity | 440 lbs |
