GE HealthCare - Millennium MG
by GE HealthCare
Dual-head gamma camera.
The Millennium MG is a compact nuclear medicine camera featuring two rectangular, variable angle detectors, which may be oriented in either the 180° or the 101° position. The MG is an all-purpose multi-geometry (variable angle) nuclear camera designed to perform a full range of nuclear medicine studies and provide complete clinical flexibility.
3RepliesTue Feb 11 2020 | Patient List Disappears When looking at the patient selector on the acquisition station, we can only see studies from the current day. We used to be able to see all studies that were on the local database until we manually deleted them, but now they disappear everyday and show only those from the current day. I know they are still there, because it says the local database is 70% full. We need this list to document QC values, send files to PACS and delete studies when they are completed, so we need to have at least several days worth of studies listed. Have we changed a setting somewhere that causes only current studies to be listed?Reply |
5RepliesTue May 22 2018 | Genie 4.5 good afternoon I have a millenium mg somebody knows where I can download the genie 4.5Reply |
1ReplyThu Sep 15 2016 | Annual maintenance contract for Millenium MG gamma camera How much will be the Annual Maintenance Contract amount and Comprehensive maintenance contract amount for a Gamma camera Millenium MG How much % of the value of equipment , if we are taking directly from GE healthcare. Please share
Thanks Reply |
| Crystal Thickness | 9.5 mm |
| Power Requirements | 110/120 VAC |
| Weight | 3920 lbs |
| Detector Geometry | Dual-head variable angle |
| Detector Material | Sodium Iodide |
| Gamma Camera Type | SPECT |
| Gantry Configuration | Variable |
| Patient Weight Capacity | 440 lbs |
