GE HealthCare - Ventri
Small footprint, dedicated cardiac dual-head gamma camera.Ventri is a compact cardiac-optimized nuclear imaging system. It is comprised of two detectors in a 90° geometry mounted on a ring gantry, a compact 2-axis imaging table and a dedicated acquisition station. It can support both supine and prone imaging. Ventri is networked to the Xeleris Processing & Review Station, which features a comprehensive set of Cardiac applications. The Ventri was developed for the nuclear cardiology success. The special design of the system allows to image over 99% of the patients in optimal comfort conditions. This way, patient motion is reduced for outstanding image quality, improved diagnostic confidence and efficiency. Easy installation was also in mind with a very small system footprint (2.4*3.1m²) to fit within compact spaces and a quick 2 days installation.
SERVICE COMPANIESView All Nuclear Medicine-Gamma Camera Companies
- Small 37 x 19 cm² field-of-view detectors
- Unique all-digital Elite detector design with one ADC per PMT
- Crystal thickness: 9.5 mm (3/8”): optimal for low energy imaging, especially for Tl-201 and Tc-99m scans
- Extensive Xeleris clinical library with sophisticated processing capabilities
- Small (2.4x3.1)m² footprint to fit within compact spaces
- Quick, average 2 days installation
- VentriCare™ Arm & Leg Supports for optimized patient comfort
- VentriCam™ wall-mounted patient positioning camera
- Ignite™ workflow automation in standard
Crystal Thickness | 0.375 in |
Power Requirements | 115 VAC |
Detector Geometry | Dual-head 90 degrees |
SPECT/CT Module | 0 |
Detector Material | Sodium Iodide |
Gamma Camera Type | SPECT |
Gantry Configuration | Open |
Patient Weight Capacity | 440 lbs |
