GE HealthCare - Millennium VG
by GE HealthCare
The Millennium VG (formerly Elscint Varicam) is a dual head, multi geometry (variable angle) nuclear medicine camera with LFOV detectors. The VG was designed for general purpose studies and is capable of whole body, planar and SPECT imaging.
3RepliesSun Mar 29 2026 | software load Hi All, trying to load the elscint app i get error: "unable to transfer install.ex$ to the temporary location" in a titled window: install.ex$ not decompressed. this after os2 load successfully. WS is a Dell 1400SC. Thanks and best regards, Miguel Cabrera Reply |
1ReplyFri Apr 29 2022 | Equipment Disassembly Does anyone have drawing to show how this equipment breaks down for shipping? Asked by a customer to move one in CA but they do not have the drawings or anything that shows how it breaks apart. It needs to come out a door that is 47" wide but as it sits that main body is 67"x67"x79" (LxWxH)Reply |
1ReplySat Dec 08 2018 | Gantry no rotation - Main input voltage was set to 208 V ac during installation - IPS fuses OK, AC outputs to drivers checked, in specs - Stator power supplies were checked, 5.2 V, +14.92 V, -14.77 V - Safety and door interlocks checked, work properly. Also, emergency stops - When gantry and acq. Computer is turned on: PSD TEST, psd in head 1 and 2 pressed. SYSTEM TESTS press START, start is pressed. INITIALIZATION, remove patient and press ENTER, ENTER is pressed. INITIALIZATION, press START to initialize axes, start is pressed. After few seconds, system ask again, remove patient and press ENTER and so on - With program PANEL I am able to exercise radial, swivel, lateral, bed linear and height, but no rotation. - All FE functionality test pass Most of FE communications test pass, but all tests related to rotation does not pass. I attached some Reply |
| Height | 83 in |
| Length | 69 in |
| Weight | 5600 lbs |
| Detector Geometry | Dual-head variable angle |
| Gamma Camera Type | SPECT/CT |
| Patient Weight Capacity | 440 lbs |
| Width | 83 in |
