MEDX - T-Quest
Thyroid and small-organ cameraThe T-Quest is a compact gamma camera designed to perform thyroid, parathyroid, sentinel node, MUGA, gastric emptying, hepatobiliary, bone spots and other studies. It allows you to keep your high-end equipment performing high-revenue studies resulting in increased throughput and higher departmental revenues. The T-Quest™ requires less than eight square feet of floor space and provides superior multivendor DICOM compatibility. The redesigned platform provides high-quality imaging capabilities as well as the freedom to perform long duration time/activity studies. The results of this combination are increased operating efficiency, better imaging economics and improved diagnostic results
SERVICE COMPANIESView All Nuclear Medicine-Gamma Camera Companies
- Open, inviting design accomodates patients of any size and improves patient satisfaction
- Increased patient throughput
- Higher department revenue
- Fewer time-consuming LFOV collimator exchanges
- Optimal image quality and statistical analysis
- Exceptionally low lifetime cost of ownership
- Circular 150mm FOV
Crystal Thickness | 9.5 mm |
Weight | 729.9 lbs |
Detector Geometry | Single-head |
SPECT/CT Module | 0 |
Gamma Camera Type | Non-SPECT |
Patient Weight Capacity | 297 lbs |
