Philips - BrightView XCT
by Philips
SPECT/CT System
BrightView XCT is a SPECT/CT system designed entirely for nuclear medicine. We took a deeper understanding of what works for you and your patients and combined it with advanced intelligence in technology and services. CoPlanar FP uniquely integrates Philips BrightView SPECT in a co-planar design with advanced Philips flat-detector X-ray CT technology.
-Petra
12 years ago
CT does not overlap with SPECT myocardial
Hello, I need to know where is the problem in the setting of SPECT / CT infarction. Ct infarction resulting image is shifted down to the SPECT image infarction. The images do not overlap. Thank you very much Gulyásová
-MedWrenchManager
14 years ago
Philips introduces BrightView XCT
June 16, 2008 Philips Healthcare is introducing BrightView XCT, a new SPECT/CT scanner, at this week's annual SNM meeting in New Orleans. BrightView XCT integrates the vendor's BrightView SPECT coplanar gamma camera with flat-panel detector CT technology, according to the Andover, MA-based vendor. Philips believes the coplanar SPECT and CT capabilities will limit the need to move the table between scans. It can also fit into a 12 x 15-ft room, the company said. In other Philips SNM announcements, the company is demonstrating its Gemini TF Big Bore scanner and a new nuclear medicine application portfolio on its Extended Brilliance Workspace application. Designed for use in radiation oncology applications, Gemini TF Big Bore features an 85-cm bore for PET and CT scans, according to the firm. It combines Philips' Gemini TF time-of-flight PET imaging functionality with its Brilliance Big Bore CT localization technology. The first system will be installed later this year at the Perelman Center for Advanced Medicine at the University of Pennsylvania Health System in Philadelphia. The firm's new nuclear medicine application portfolio provides a common analysis and viewing environment for SPECT, PET, and CT images, as well as support for hybrid imaging, Philips said. [url=http://www.auntminnie.com/index.asp?Sec=nws&Sub=thd&pag=dis&ItemId=81470]Aunt Minnie-Original Article Source[/url]Reply
SERVICE COMPANIESView All Nuclear Medicine-Gamma Camera Companies
  • BrightView XCT enables low patient dose levels, high-resolution localization, and high-quality attenuation correction with the potential for fewer artifacts and shorter exam times.
  • BrightView XCT puts patients at the center of care. The patient zone is designed to create an optimum physical and emotional environment for patients. Flexible breathing protocols offer greater patient comfort. An ultra-large gantry aperture provides an open patient experience. Table limit is 500 lbs (227 kg).
  • BrightView XCT features proven BodyGuard automatic contouring to speed set up and ZeroGap planar imaging to allow minimum detector-to-detector distance of 0” (0 cm) for closer positioning.
  • BrightView XCT can acquire the entire heart volume in just one rotation and permits patients to breathe normally during SPECT and CT acquisitions. The system improves registration confidence between emission and transmission maps because the table remains stationary in many cases. Astonish reconstruction technologies can cut acquisition time in half.
  • The new NM Application Suite helps to streamline your workflow, saving you time reviewing and analyzing studies.
  • Now you can add CT without adding real estate. Surprisingly compact and easy to install, BrightView XCT fits into a room as small as 15’ 6” x 12’ (4.72 x 366 M) with minimal shielding and no need to specially reinforce flooring in most cases.
  • BrightView XCT is designed specifically for nuclear medicine and does not require CT retraining for nuclear medicine technicians.
Crystal Thickness0.375 in
Slices140
Power Requirements480 VAC
Weight4500 lbs
Detector GeometryDual-head variable angle
SPECT/CT Module1 Standard
Detector MaterialSodium Iodide
Gamma Camera TypeSPECT/CT
Gantry ConfigurationOpen
NEWSView All
June 16, 2008 Philips Healthcare is introducing BrightView XCT, a new SPECT/CT scanner, at this week's annual SNM meeting in New Orleans. BrightView XCT integrates the vendor's BrightView SPECT coplanar gamma camera with flat-panel detector CT technology, according to the Andover, MA-based vendor. Philips believes the coplanar SPECT and CT ca...
