Philips - CardioMD
Nuclear Cardiology Camera
CardioMD is a compact, fixed 90-degree nuclear cardiology camera that brings cardiac assessment capabilities to your practice and department in ways that work for you, your patients, and the future of healthcare. There's a reason Philips systems are found in so many cardiology settings: CardioMD meets the most stringent clinical criteria.
FORUMSView All (3)
0Replies3 years ago | ERROR NO CONNECTION TO GANTRY Check the IEEE 1394 CABLE CONNECTION. Used to be occasional, then frequently, and now daily. Have to turn off the computer, and then turn off the CardiMD multiple times. Is there a fix ?Reply |
0Replies4 years ago | SOftware installation guidance required Hi Anyone can Help for Philips Nuclear Gamma Camera CardioMD software Installation Guidance? Thanks Reply |
4Replies6 years ago | Mobile capable? Would this system be abke to be put in a mobile outreach application? Anybody heard of a mobile anchoring kit? Looking for a small FOV that could go mobile.Reply |
SERVICE COMPANIESView All Nuclear Medicine-Gamma Camera Companies
- Light weight
- 4 Table cut-offs for closer imaging capabilities
- Rectangular 370mm x 214mm
Crystal Thickness | 9.5 mm |
Power Requirements | 110 VAC |
Weight | 2425 lbs |
Detector Geometry | Dual-head 90 degrees |
SPECT/CT Module | 0 |
Detector Material | Sodium Iodide |
Gamma Camera Type | SPECT |
Gantry Configuration | Open |
Patient Weight Capacity | 400 lbs |
