Positron - Pulse CDC
Compact digital cardiac cameraCompact digital cardiac camera that can be installed in any orientation to accommodate various room layouts. Features an automatic patient loading system for supine and prone imaging.
0Replies9 years ago | Sample of Thallium Scan of Heart Hello, I am student of MS(Electrical). Presently doing thesis on 3D modeling of heart using Thallium data sets. I have got images which are output of software provided by company. But i require video which is in raw form to manually extract images. Because images available are not sufficent to enough to make 3D model. I request for any sample recording of Thallium scan of heart for my thesis. Please email me the video sample of your machine at khangee_99@yahoo.com I will be really thankful for your kind effort in this regard. Ahmed Reply |
SERVICE COMPANIESView All Nuclear Medicine-Gamma Camera Companies
Fast and efficient patient setup: The chair and bed make it easy for the technologist to position the patient. From there, setting the camera up for acquisitions is fast and efficient:
- one point non-circular and circular SPECT setup
- no need to reset the camera to a home position prior to initiating SPECT studies
- the slip ring eliminates cumbersome rotational limits
- user configurable predefined acquisition protocols permit very quick set up
- all menu driven software
- easy protocol generation
- acquisition and processing can be combined or can be at separate workstations
- menu set-up and protocols can be run from both the hand control and the acquisition workstation
Crystal Thickness | 9.5 mm |
Power Requirements | 120 VAC |
Weight | 1850 lbs |
Detector Geometry | Dual-head 90 degrees |
SPECT/CT Module | 0 |
Detector Material | Sodium Iodide |
Gamma Camera Type | SPECT |
Gantry Configuration | Closed |
Patient Weight Capacity | 450 lbs |
