Siemens - Symbia T Series
A Merger of True EqualsThe Siemens Symbia T SPECT-CT System combines a dual-head variable-angle gamma camera with a CT scanner for rapid attenuation correction (T or T2 = 2 slice), advanced oncology and neurology imaging (T6 = 6 slice) or excellent oncology coverage (T16 = 16 slice). This system carries the same features as the Symbia S, but already incorporates the TruePoint SPECT-CT option.
FORUMSView All (4)
1Replya year ago | I NEED THE SERVICE AND INSTALLATION GUIDE MANUAL I NEED THE INSTALLATION GUIDE MANUAL Equipment: SIEMENS SIMBIA T SERIES Reply |
3Replies9 years ago | Can someone explain when and why PMs moved from 1 to2 per year? thanks! Reply |
1Reply10 years ago | Ask for Symbia t
Reply |
SERVICE COMPANIESView All Nuclear Medicine-Gamma Camera Companies
- Automatic body contour for SPECT and whole body imaging
- Flash 3-D iterative reconstruction
- Rectangular 533mm x 387mm FOV
Crystal Thickness | 9.5 mm or 15.9 mm |
Power Requirements | 380 to 480 VAC |
Weight | 9760 lbs |
Detector Geometry | Other |
SPECT/CT Module | 1 Standard |
Detector Material | Sodium Iodide |
Gamma Camera Type | SPECT/CT |
Gantry Configuration | Other |
