Baxter - SIGMA Spectrum
by Baxter
Designed with you and your patients in mind.
The SIGMA Spectrum Infusion System has features that help reduce errors when programming an IV infusion. For example, the SIGMA Spectrum Infusion System automatically defaults to using the drug safety library at the initial start of the system. Small, lightweight and easy-to-use, the SIGMA Spectrum Infusion System also offers wireless connectivity to integrate data into a hospital’s EMR system and facilitate the transfer of data to and from the system for updating drug libraries as well as for continuous quality improvement reports. Rx Only. For safe and proper use of this device, refer to the complete instructions in the Operator’s Manual.
1ReplyMon Aug 11 2025 | Remove power cord from metal clamp How do you remove the power cord connection from the back of the Sigma Baxter infusion pump I unscrewed one screw but there are two tiny screws like stubs. Also, how do you remove that so I can change out the power cord? Equipment: Sigma baxter infusion pump Reply |
2RepliesSat Sep 28 2024 | Radio Reset: Watchdog Anyone know a fix for this network connection problem? Reply |
1ReplyFri Aug 23 2024 | Master Drug Library Download Good day all, I had to update PC's and I seem to have misplaced my Master Drug Library installation file. Does anyone know where I might be able to obtain it? My pumps are running version 6. Thank you :) Reply |
[list] [*] Multiple Prevention Systems > Configurable dose error reduction software > Single step titration limit > Check flow at start of infusion > Secondary container infusion check [*] Comprehensive log software to create CQI reports; Rapid, Intuitive Work-flow > Easy to set-up and program safely > Bright, easy to read color display > Use of Baxter's standard IV administration sets > Quick drug find library search [*] Economic Value > Utilizes Baxter's standard IV administration sets to help reduce set up time and waste > Facilitates easy training of staff [/list]
| Volume to be Infused | 0.1 to 9999 ml |
| Height | 5.8 in |
| Length | 2.5 in |
| Flow Rate Range | 0.5 to 999 ml/h |
| Weight | 2.5 lbs |
| Infusion Pump Type | General-Purpose |
| KVO Range | 0.5 to 50 ml/h |
| Width | 4.2 in |
Infusion pumps are invasive pieces of medical equipment that work to save lives through preventing dehydration, and also aid in the continual release of medication.
Baxter International Inc. announced today it has exercised its option and completed the purchase of SIGMA International General Medical Apparatus, LLC. by acquiring the remaining 60 percent of the company for $90 million.
Baxter International Inc. announced its SIGMA Spectrum Infusion System has received the "Best in KLAS" award for the second consecutive time at the 2012 Best in KLAS Awards: Medical Equipment & Infrastructure report.
Deviations from the specified cleaning methods may impair infusion pump
Recall Class:Class I Date Recall Initiated:February 7, 2014 Products: Sigma Spectrum Infusion Pumps with Master Drug Library Model No. 35700BAX and 35700ABB Affected products were manufactured from July 1, 2005
Based on additional analyses since the initial recall, SIGMA expanded their recall to include additional affected units manufactured from January 18, 2005 through November 1, 2010, with the exception as noted above. These units may fail suddenly
