GE HealthCare - Excel 210 SE
by GE HealthCare
Great for areas where a small footprint is necessary.
This anesthesia machine is great for areas where a small footprint is necessary. The 210 SE differs from the 210 in that it is a later model and has more ventilator options. O2, N2O, and medical air are standard on the Excel 210 SE. Drawer pack configurations may vary from picture.
FORUMSView All (29)
-JCBradshaw
Tue Feb 20 2024
Service manual
I'm trying to obtain a copy of the service manual.
Equipment: Excel 210SE/7900 TRM
-SERA
Thu Feb 10 2022
Need Manuel service and technique
Bass pressionReply
2
-Andy Mulley
Wed Nov 07 2018
Which gases.
Hi. I am trying to advise a hospital here in SW Uganda about a recently donated Excel 215 SE anasthaesia macihine. Can it be used with just oxygen or does it air bottle as well? Also can it run without a nitrous oxide bottle? Thanks!Reply
Key Features
  • Supports 3 gas sources and 2 vaporizers
  • Designed for powerful ventilation and monitoring in secondary anesthesia locations
  • Compact frame ideal for space-constrained environments
  • Integrated monitoring for oxygen (O‚), volume, and airway pressure
  • Enclosed, non-interchangeable pneumatic circuitry for added safety
  • Clearly differentiated pipeline and cylinder pressure gauges
  • Master On/Off switch activates both electronic and pneumatic systems
  • Link-25™ Hypoxic Mixture Guard System helps prevent delivery of hypoxic gas mixtures
  • Pin-indexed, gas-specific dual O‚ and N‚O flowmeters
  • Selectatec® vaporizer manifold accommodates two TEC 5 vaporizers
  • Guarded oxygen flush button to reduce accidental activation
  • Built-in oxygen power outlet
  • Fixed shelving with additional space for patient monitoring equipment
  • Two-drawer storage cabinet for accessories and supplies
  • Single-action brake with integrated footrest
  • Full-height dovetail accessory mounting system
  • Large, smooth-rolling casters for easy mobility
Height66 in
GasesAir, Nitrous Oxide, Oxygen
Length 27.5
Vaporizers (Max)Two
ScavengerOpen or Closed Interface
Weight300 lbs
Inspiratory Flow (max)100 L/min
Vaporizer TypeConventional pneumatic/mechanical
Vent ModesCMV, Manual/Spontaneous.
Width22 in
