Toshiba - Infinix DP-i
Dual Plane Single Room X-Ray SolutionToshiba’s Dual Plane C-arm system works like two systems in one room. Two differently sized independent flat panel detectors provide dedicated cardiac and vascular imaging. The Dual Plane system is designed to fit in a conventional-sized cardiovascular suite. The Infinix-i DP features an 8-inch-by-8-inch floor mounted flat panel detector for cardiac applications and a 12-inch-by-16-inch ceiling mounted flat panel detector for peripheral applications. The system helps maximize space while allowing for fast transition between cardiac and angiography exams.
SERVICE COMPANIESView All Cath/Angio Companies
[list] [*] One room does the work of two — Infinix DP-i/FPD is ideal for both cardiac and general angiography [*] Saves space and reduces costs — You have only one room to staff and maintain [*] Fast transition from cardiac to angio procedures — System uses the same software for both kinds of procedures, so cardiologists can rapidly switch from one C-arm to the other, boosting patient throughput [*] Optimized detectors for better anatomy match — Obtain high-quality images for accurate diagnosis from cardiac and peripheral vascular exams [*] Redundancy of imaging chains — In the unlikely event one detector goes down, the other can serve as a backup and continue to generate revenue [/list]
NEWSView All
TOSHIBA’S CARDIOVASCULAR SYSTEMS MAKE TRANSRADIAL APPROACH...
Three Different Infinix-i X-ray Systems Optimize Harrison Medical Center Patient Throughput for Interventional Cardiac, Peripheral and EP Exams
