STERIS - 5085 SRT
by STERIS
The 5085 SRT is a crossover table that slides, rotates and transports patients throughout the perioperative area and is the only surgical table cleared by the FDA for patient transport, according to the company. A drive wheel allows one caregiver to safely transport a patient from pre-op to OR to post-op without red-zone gurneys or trolleys. In pivot mode, the drive wheel locks and rotates 360 degrees, without support posts or weight calculations. An intuitive hand control with an LCD window telegraphs table-positioning data and allows one-touch patient posturing. The four-section tabletop articulates to a variety of patient postures. The 5085 table can be upgraded to the SRT at any time by adding the drive wheel and head section. Both tables are configured to enable ACT (Advanced Control Technology) software and are compatible with previously purchased STERIS accessories.
3RepliesTue Apr 07 2026 | Connect AC Plate Error Good day, I am having issues with the power for the table hence the connect AC plate error. The fuses keep blowing, I am out of 4A fuses, so I tried yth3.15A and they blow instantly. I no longer have the service manual due to unexpected circumstances, so I am asking for any help and tips. I am located in Iraq, so we are using 230-250V. The unit has recently moved under not ideal situation, so I am not sure if something got damaged during the relocation. I am trying to acquire T4AH fuses that are on the data plate, but I feel like there might be something else wrong with the table. Thank you in advance for any assistance provided. Reply |
0RepliesTue Mar 21 2017 | is working good? is the table working good?what accessories it comes with?Reply |
2RepliesMon Aug 15 2016 | Dragging Brakes I have a Steris 5085 SRT OR table that two of the four brake feet will not fully raise and drag making the table hard to move. Does anybody know how to fix this problem? Reply |
[list] [*] The intuitive hand control has pre-programmed positions for rotation and beach chair for easy set up [*] The hand control's LCD window telegraphs table positioning data to caregivers, even in a darkened room. [*] Contours to virtually all patient postures with a four-section tabletop [*] Provides unrestricted perineal access with removable leg section [*] Enhances lateral procedures with a powered, radiolucent kidney elevator [*] Accommodates virtually all patients with generous height and weight ranges [*] Provides outstanding access for C-arm, permitting clear high-quality images crucial to MIS, cardiothoracic, orthopedic and neurosurgical procedures [*] Compensates for uneven OR floors with unique self-leveling floor locks [*] Prevents sectional and table base collisions with the Auto Limit Sensor™ [*] Compatible with a wide array of previously purchased accessories [/list]
| Height | 22.8 in to 42.5 |
| Length | 83 in |
| Weight | 850 lbs |
| Tredelenburg | 30 degrees |
| Lateral Tilt | 20 degrees |
| Patient Weight Capacity | 1200 lbs patient support, including raise/lower (centered on the column) |
| Width | 20 in |
Table Slide Range 9" (227 mm) to head, 9" to foot Table Rotation 360° Head Section +90° to -90° (10° increments) Back Section +80° to -40° Leg Section 0° to -105° Flex/Reflex 140° / 100° Manual Override Yes Perneal Cut-out Yes Kidney Elevator 4" (110 mm) powered
This month, OR Today explores current trends in operating tables.
This month, Medical Dealer explores the latest trends in operating tables and lighting systems.
