Draeger - Narkomed 6000
Volume, Pressure and SIMV modes of operationThe 6000 series machines were first launched in 1998 and were the first model in cooperation between Drager Germany and North American Drager in Telford PA. The machine utilizes the German designed Divan ventilator that is a under the table top piston ventilator. The ventilator controls are soft key LED numerics with a trim knob located below the table top. The aluminum encased heated compact breathing system provides enhanced performance over prior models. The 6000 series has a color touch screen display for all ventilator parameters including built in gas analysis. An optional IPM module that adds multi parameter patient monitoring is available. The vaporizers are positioned on the left side of the machine and there are 2 positions. The unit has one drawer and a built in auxiliary oxygen flow meter. The production of this model ended in 2007.
FORUMSView All (11)
0Replies5 years ago | No Video Detected. Hello, We tested and PM'd a unit here in the States and shipped it overseas as a donated unit. When the machine got there, we were informed that the video is not working. Only an error message displayed stating "No Video Detected". We are assuming something got disconnected during transportation. Will be grateful if someone can help us out to rectify this issue. We currently don't have Antoine volunteering with expertise to handle it for us. Reply |
2Replies6 years ago | servise manual Dear sir/madam... I need support on how to reset narkomed 6000 Reply |
3Replies6 years ago | Service manual Service manualReply |
[list] [*] Flowmeters: traditional mechanical/pneumatic (needle valves and glass flowtubes), but electronic capture of fresh gas flows has recently been added. Minimum oxygen flow 150 mL/min. Pneumatic ORC (oxygen ratio controller) for hypoxic guard. [*] Breathing circuit: The absorber head is warmed, and the breathing circuit is lower volume (1.5 L absorbent volume). Only loose carbon dioxide absorbent granules may be used. The machine is not compatible with non-rebreathing circuits. [*] Electrical power failure: 30 minute battery reserve with fresh gas, vaporizers, monitors, and ventilator operational. [/list]
Height | 86.4 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 83.5 in |
Vaporizers (Max) | Two |
Scavenger | Open or Passive interface |
Weight | 498 lbs |
Inspiratory Flow (max) | 75 L/min |
Vaporizer Type | Variable-bypass |
Vent Modes | volume control (VCV), pressure control (PCV), synchronized intermittent mandatory ventilation (SIMV), Manual/Spontaneous. |
Width | 144.8 in |
