Datex Ohmeda - Modulus SE
3 vaporizer position machine.The Modulous SE is a 3 vaporizer position machine that can be equipped with either the 7800 ventilator (Volume only) or the 7900 ventilator (Volume, Pressure). The Modulous series of machine offer wider frame and drawer space. The units were first produced in 1994 and production ended 2001. The units are still very popular as they meet all ASTM standards, many years of serviceable life remain and the units are great for achieving features to meet needs within tight budgets.
FORUMSView All (12)
2Replies3 years ago | bad Oxygen regulator Need new or refurbished Oxygen regulator for Datex Ohmeda Modulus SE.Reply |
2Replies5 years ago | Oxygen sensor needed Can anyone help me find the part number for the oxygen sensor for the Ohmeda Modulus SE? Or if anyone has a parts list manual for thisReply |
2Replies7 years ago | george2 Are there any flow sensors available for Datex Ohmeda SE with 7900 ventilator? Also need in line water trap Reply |
[list] [*] Tek 5 Vaporizers [*] 7800 Electronic Ventilator [*] Traditional size, configuration of absorber head and higher-volume breathing circuit [*] Loose absorbent granules or canisters [*] Removable vaporizers [*] Can be used with no-rebreathing circuits [/list]
Vaporizers (Max) | Three |
Scavenger | Open or Closed Interface |
Weight | 306 lbs |
Vaporizer Type | Variable-bypass |
Vent Modes | CMV, PCV (with SmartVent) |
