Datex Ohmeda - Aestiva/5
by Datex Ohmeda
More than superior ventilation.
The Aestiva 5 offers exceptional capabilities and flexibility, giving a cost-effective approach to anesthesia therapy.
The Aestiva 5 with SmartVent offers users selected capabilities of an intensive care ventilator, saving users the cost of bringing a separate ICU ventilator into the OR. Its flexible ergonomic design and intuitive operations enhance SmartVent's capabilities to give users a higher level confidence and control. In addition, the Aestiva/5 provides an optimized system for the practice of low and minimal flow anesthesia, minimizing agent consumption to save on anesthetic agent costs.
The Aestiva 5 open architecture gives users the flexibility to use their current monitors and data management systems, helping users stay within their budget while achieving physical integration in one unit. The Aestiva/5 also has built-in service diagnostics making service support easy and cost efficient.
1Reply7 years ago | Calibration of Flow Sensor Difference between Inspiratory and expiratory Volume is 100ml , How do i calibrate flow sensor , Unit is Aestiva 5 with 7900 Ventilator Reply |
6Replies7 years ago | Calibration of Flow Sensor Difference between Inspiratory and expiratory Volume is 100ml , How do i calibrate flow sensor , Unit is Aestiva 5 with 7900 Ventilator Reply |
2Replies9 years ago | outlets What are the recommendations for using outlets on the anesthesia machine? Reply |
Superior ventilation
Open systems architecture
Innovative patient breathing system
Improved low flow/reduced life cycle costs
Height | 52.9 in |
Length | 28.7 in |
Vaporizers (Max) | Three |
Scavenger | Closed interface |
Weight | 238 lbs |
Vaporizer Type | Variable-bypass |
Vent Modes | VCV, PCV, SIMV (optional), pressure support ventilation (PSV), Manual/Spontaneous. |
Width | 28.3 in |
